Hi there,
I have the following conditional rule in a dashboard indicator:
[edit]: {{value-0}} is the next service date showing in the preview, formatted as follow:
{{formatDate value-0 ‘DD/MM/YYYY’}}
It’s working fine in the preview, and when I test it in the experience I get the expected result:
Now I jump onto another computer and the condition is triggered even though the condition is not met:
Any idea what could be wrong?
The {{formatDate}} helper, when used in a dashboard, will use the current browser locale when formatting. The format string follows Moment.js format syntax, and the default is L LTS.
For example, in your first browser, which appears to be set to English, this will return 12/19/2022 4:00:00 PM
In your second browser, which appears to be set in French, this would return 19/12/2022 16:00:00
I believe if you format both dates in the expression to DD/MM/YYYY, it will evaluate consistently across multiple locales. If that doesn’t fix the issue, please DM me the workflow file and we’ll troubleshoot further.
Thanks @Sebastian_Turner, I have change the formatting to ‘x’ in the condition, it seems to have fixed it.
