I’m trying to use an Arduino MKR NB1500 to upload load cell data to Losant. The board connects but instantly disconnects. After a lot of google and head against my desk banging, I’m here asking for help. Hopefully, I’m not doing something really dumb.
I have an activated Hologram SIM card and Hologram reports the device as connected.
Losant Log:
Serial Monotor:
#include <MKRNB.h>
#include <Losant.h>
#include "arduino_secrets.h"
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
const char PINNUMBER[] = SECRET_PINNUMBER;
// Losant credentials.
const char* LOSANT_DEVICE_ID = "xxxx38";
const char* LOSANT_ACCESS_KEY = "81bxxxx63";
const char* LOSANT_ACCESS_SECRET = "1xxxx1";
int losantAttempts = 0;
#define SECRET_PIN " "
#define SECRET_GPRS_APN "hologram"
#define SECRET_GPRS_LOGIN " "
#define SECRET_GPRS_PASS " "
const char GPRS_APN[] = SECRET_GPRS_APN;
const char GPRS_LOGIN[] = SECRET_GPRS_LOGIN;
const char GPRS_PASSWORD[] = SECRET_GPRS_PASS;
// initialize the library instance
NBClient client;
GPRS gprs;
NB nbAccess;
NBScanner scannerNetworks;
String signalStr;
String carrier;
// URL, path and port (for example: example.org)
char server[] = "cloudsocket.hologram.io";
char path[] = "/";
int port = 9999; // port 80 is the default for HTTP
float ambTemp = 0;
float LPTank1 = 0;
float LPTank2 = 0;
float LPTank3 = 0;
float LPTotal = 0;
void setup() {
// initialize serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Starting Arduino web client.");
// connection state
boolean GSMconnected = false;
// After starting the modem with NB.begin()
// attach to the GPRS network with the APN, login and password
while (!GSMconnected) {
if (nbAccess.begin(PINNUMBER) == NB_READY) {
GSMconnected = true;
Serial.println("GSM connected");
else {
Serial.println("Not connected");
delay(1000);
carrier = scannerNetworks.getCurrentCarrier();
signalStr = scannerNetworks.getSignalStrength();
Serial.print("Carrier: ");
Serial.println(carrier);
Serial.print("Signal Strength: ");
Serial.println(signalStr);
boolean GPRSconnected = false;
Serial.println("GPRS Connecting..");
while (!GPRSconnected) {
if (gprs.attachGPRS() == GPRS_READY) {
GPRSconnected = true;
Serial.println("GPRS Connected");
delay(2000);
else {
Serial.println("GPRS Connection Failed");
delay(1000);
delay(2000);
Serial.print("Connecting to Losant");
device.connect(client, LOSANT_ACCESS_KEY, LOSANT_ACCESS_SECRET);
while(!device.connected()) {
Serial.print(".");
delay(500);
Serial.println("CONNECTED!!!");
void loop() {
ambTemp = random(60,100);
LPTank1 = random(65,70);
LPTank2 = random(65,70);
LPTank3 = random(65,70);
LPTotal = LPTank1 + LPTank2 + LPTank3;
Serial.println("Sending Data..");
StaticJsonDocument<200> jsonBuffer; //220 is MAX Size or Losant Disconnects
JsonObject allData = jsonBuffer.to<JsonObject>();
allData["AmbTemp"] = ambTemp;
allData["LPTank1"] = LPTank1;
allData["LPTank2"] = LPTank2;
allData["LPTank3"] = LPTank3;
allData["LPTotal"] = LPTotal;
device.sendState(allData);
Serial.println(" Data Sent");
device.loop();
delay(10000);
The first thing to check is whether you can connect to any broker at all. Here’s a snippet that connects to Eclipse’s public sandbox broker. Give that a try.
Good first step. The next thing to check is whether you can connect to Losant’s broker using that MQTT library. That example is using ArduinoMQTTClient. Losant’s Arduino library is using arduino-mqtt.
Losant’s library is a thin wrapper around the underlying MQTT library. There’s nothing wrong with using any MQTT library directly if it works.
Before line 50, mqttClient.connect(...), you’ll need to add these two lines:
Just as a sanity check, can you check Losant’s application/device log? I’m assuming you’re using a default access key and secret, which does not let you subscribe to custom topics (i.e. telstradev). The connection would have succeeded, but you would have been subsequently disconnected when that subscribe was attempted.
That’s expected. You are attempting to publish to the custom topic, telstradev, however access to that topic was not granted to your access key, so the broker disconnects your device.
The subscription to the telstradev topic also failed, but invalid subscribes are silent failures on our broker - they don’t disconnect the device. I incorrectly stated that invalid subscribes will cause a disconnect in my previous post.
You can find more details about using custom topics here:
All that said, you now have a path forward. I would recommend using this MQTT library directly. To publish state, you need to send a message to the topic losant/YOUR_DEVICE_ID/state. The format of the payload is:
I changed the topic to state and it seems I am staying connected now but I’m having trouble getting data sent to Losant. Do you have an example of that?
I don’t have an example, but according to the log, it doesn’t appear that any publish was attempted by the device. For example, if you publish with an invalid payload, you’d get a message like this:
In your previous attempt, the example code was publishing data because the broker disconnected the device due to an unauthorized topic. I would recommend trying the example code again and only changing the topic.
Getting your code to compile, unfortunately, isn’t something we’re going to be able to help with. However, you did have the example running 2 days ago and connecting. I recommend going back to that and slowly and incrementally adding functionality. The first step will be using the code from 2 days ago and changing just the topic string.
