Allow access to last GPS frame outside duration window in Map Block
I would like to make a ticket for including a pin variable for supporting display of data in the “Advanced Pin Style” section of the map block. The variable I am requesting would allow the display of the last valid GPS location attribute for a given device regardless of the selected duration.
The application of this would be to allow for devices which haven’t reported within the last x days to still be displayed on map, albeit potentially with a different colour to indicate the validity of the location. I would think this variable would essentially behave the same as the pin marker behaves when the duration is selected on the map widget as “Last Received Data Point”.
