[Solved] Workflow Export
Has something happened to workflow export functionality? I see import under settings but export has disappeared.
With the release yesterday, as part of the UI changes for workflow versioning, export has moved to a different location - take a look at the import/export documentation. You can also read about the platform updates in general in yesterday’s blog post. Hope that helps!
