I am attempting to create a workflow that takes a status code from our device {{data.Status}} and translates that to the text definition of the code for alerts via text or email.
I have set up a data table with two columns, Code and Code Description. I have been unsuccessful in using the device status to reference the description column that corresponds to the Status code.
I read about an option to use the switch logic to match the code to a text string - Is there a better way?
Thank you for your help.
I think you’re on the right path. Data Tables are a great way to map status codes to text definitions. Here’s an example I put together to help answer this:
It’s got two status codes (100, 200) with text for each.
In the workflow, you can then use the Table: Get Rows Node to query your Data Table by the value of the incoming status code:
The results of the query, in the above screenshot, are put back on the payload at data.result
. You can then access the results and the text
column using the following template:
{{ data.result.items.[0].text }}
Using a Debug Node, you can inspect how Data Table results are placed on the payload:
So if you wanted to send an SMS with the status text, you could do something like:
Your device reported status with the following description:
{{ data.result.items.[0].text }}.
Thank you very much! I was missing the template to access the text.
It is working now.
Excellent! Glad we got it figured out.
