# \[SOLVED\] Toggle Input Dynamic Default Value
**URL:** <https://forums.losant.com/t/solved-toggle-input-dynamic-default-value/268>\
**Category:** Feature Request\
**Created:** [October 13, 2016, 8:28pm UTC](https://forums.losant.com/t/solved-toggle-input-dynamic-default-value/268 "2016-10-13T20:28:52Z")\
**Showing post:** 2
**Author:** ![Dylan\_Schuster](https://sea1.discourse-cdn.com/flex015/user_avatar/forums.losant.com/dylan_schuster/32/2850_2.png) [@Dylan\_Schuster](https://forums.losant.com/u/Dylan_Schuster)\
**Post date:** [October 13, 2016, 8:51pm UTC](https://forums.losant.com/t/solved-toggle-input-dynamic-default-value/268/2 "2016-10-13T20:51:08Z")
We’re covering this same topic in a separate forum post here -
> [@\[SOLVED\] Input controls even as output?](https://forums.losant.com/t/input-controls-even-as-uotput/262):
> I really like the new input controls that lets me e.g. switch on the heating pump in my vacation house. However if I turn on the heating pum manually, I would have to create a indicator block to see the actual state of the heating pump relay. It would be much more convenient to be able to set the state of a control e.g. a toggle control to reflect the actual state of the device’s senors / activators. In other words - Input/output controls!!
This is becoming a common request so we’re looking into how best to implement this. Getting this functionality in place will take major changes to the current input controls block. We’ll keep you posted.
_[View the full topic](https://forums.losant.com/t/solved-toggle-input-dynamic-default-value/268)._
