Should the Info Window feature from Google Maps overlays work? I tried some things and can draw circles on the map, but I cannot get the Info Window type of overlay to work.
I’d like to show some text next to the dots.
https://developers.google.com/maps/documentation/javascript/overlays#CustomOverlays
I’m assuming this is in reference to the Custom HTML Block? Google Maps falls outside our area of expertise but I do have some experience working with them; if you can paste a code sample here, I can take a look and see if anything jumps out.
Make sure to remove any API keys or sensitive information before pasting the code.
Yes, the Customer HTML Block. Well nuts, I had deleted my previous code and then attempted to find some example for you. In doing so, i was able to get this to work:
Let’s say I want to print the number 10 on the map in a marker. This code works, presuming the map has been defined and plots circles whatnot:
var marker = new google.maps.Marker({
position: center,
label: "10",
map: map
Or if it’s a variable you want to show (my goal) then this works too:
someInteger = 10;
position: center,
label: someInteger.toString(),
map: map
https://developers.google.com/maps/documentation/javascript/markers#marker_labels
Glad to hear you got it working, and thanks for posting your solution for future users!
