Selected temp measurements
#1
I have a process where I measure 2 temperatures.
The interesting measurement is the difference of those temperatures.
But it’s only interesting if the temperature is above 100 F.
How do I best approach only trending/averaging the temp diff when it’s above 100 F.
A workflow adding a calculated value to the payload if temp is above 100?
#2
I would recommend another attribute on the device to store the difference values. A workflow would then be used to calculate and report the difference only if the value is greater than 100.
#3
Would you store away the “daily”, Weekly, Monthly averages in a attribute too, or a table?
#4
How would I best go back in time and record this calculated average , for example, per day, to a new attribute?
#5
I wouldn’t store aggregations, because if they’re saved on device attributes, you can generally calculate those at any time using the Gauge and Time Series dashboard blocks and workflow nodes.
#6
Going back in time and re-calculating those is not something you’ll be able to do within the platform itself. If I had to approach that problem, I’d export the device data and then use a Node script to calculate the new value and record it back on the device. If you record a new attribute on the exact same millisecond as an existing data point, the platform will essentially merge those together into a single device state.
The script itself would work fairly similar to the CSV Import script, except you’d store a calculated value instead of what was in the CSV itself.
