No data/payload with connected device
#1
Followed instructions in ESP8266 and DHT22 getting started guide. The device is connected but no data/payload is being received by Losant? Correct data is being written to serial port.
#2
Hi Rudi!
Would you be able to post the code? ( Make sure to take out device ID, key, and secret )
#3
//This is straight from the online example: https://www.losant.com/blog/getting-started-with-the-esp8266-and-dht22-sensor
 * Example for sending temperature and humidity
 * to the cloud using the DHT22 and ESP8266
 * https://www.losant.com
#include "DHT.h"
#include <ESP8266WiFi.h>
#include <Losant.h>
#define DHTPIN 4     // what digital pin the DHT22 is conected to
#define DHTTYPE DHT11   // There are multiple kinds of DHT sensors
DHT dht(DHTPIN, DHTTYPE);
// WiFi credentials.
const char* WIFI_SSID = "WiFi";
const char* WIFI_PASS = "xxxx";
// Losant credentials.
const char* LOSANT_DEVICE_ID = ""; //removed for security
const char* LOSANT_ACCESS_KEY = ""; //removed for security
const char* LOSANT_ACCESS_SECRET = ""; //removed for security
WiFiClientSecure wifiClient;
void connect() {
  // Connect to Wifi.
  Serial.println();
  Serial.println();
  Serial.println(WIFI_SSID);
  WiFi.persistent(false);
  WiFi.mode(WIFI_OFF);
  WiFi.mode(WIFI_STA);
  unsigned long wifiConnectStart = millis();
    // Check to see if
      Serial.println();
      Serial.print("SSID: ");
      Serial.print("Password: ");
      Serial.println(WIFI_PASS);
      Serial.println();
    delay(500);
    Serial.println("...");
    // Only try for 5 seconds.
    if(millis() - wifiConnectStart > 5000) {
      Serial.println("Failed to connect to WiFi");
      Serial.println("Please attempt to send updated configuration parameters.");
      return;
  Serial.println();
  Serial.println();
  HTTPClient http;
   *     "deviceId": "575ecf887ae143cd83dc4aa2",
   *     "key": "this_would_be_the_key",
   *     "secret": "this_would_be_the_secret"
  String buffer;
  root.printTo(buffer);
  if(httpCode > 0) {
      if(httpCode == HTTP_CODE_OK) {
      } else {
        if(httpCode == 400) {
        } else if(httpCode == 401) {
        } else {
    } else {
  http.end();
  // Connect to Losant.
  Serial.println();
  while(!device.connected()) {
    delay(500);
    Serial.print(".");
  Serial.println("Connected!");
  Serial.println();
void setup() {
  Serial.begin(9600);
  Serial.setTimeout(2000);
  while(!Serial) { }
  Serial.println("Running DHT!");
  connect();
  root["humidity"] = humidity;
  root["tempC"] = tempC;
  root["tempF"] = tempF;
  device.sendState(root);
  Serial.println("Reported!");
int timeSinceLastRead = 0;
void loop() {
   bool toReconnect = false;
    toReconnect = true;
  if (!device.connected()) {
    toReconnect = true;
  if (toReconnect) {
    connect();
  device.loop();
  // Report every 10 seconds.
  if(timeSinceLastRead > 10000) {
    // Reading temperature or humidity takes about 250 milliseconds!
    // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
    float h = dht.readHumidity();
    float t = dht.readTemperature();
    // Read temperature as Fahrenheit (isFahrenheit = true)
    float f = dht.readTemperature(true);
    // Check if any reads failed and exit early (to try again).
    if (isnan(h) || isnan(t) || isnan(f)) {
      return;
    // Compute heat index in Fahrenheit (the default)
    float hif = dht.computeHeatIndex(f, h);
    // Compute heat index in Celsius (isFahreheit = false)
    float hic = dht.computeHeatIndex(t, h, false);
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print(t);
    Serial.print(" *C ");
    Serial.print(f);
    Serial.print(" *F\t");
    Serial.print("Heat index: ");
    Serial.print(hic);
    Serial.print(hif);
    Serial.println(" *F");
    report(h, t, f, hic, hif);
  delay(100);
  timeSinceLastRead += 100;
#4
This may be an obvious question. But, did you happen to set up the device attributes?
#5
Yes I followed the guide very closely I also deleted and started afresh to make sure I didnt miss anything:
#6
Sorry for the late reply on this! I’m going to run this myself now to double check the firmware.
Also, are you seeing data come up in the communication logs? You can view this on your application main page.
#7
No data in communication logs but showing device as connected. Serial monitor shows the data being sent through on serial port.
I have also been checking using request data export but no data there either.
#8
Huzzah! I think I know what it is. Check this out:
The underlying MQTT library doesn’t have configurable memory limits yet. The payload has tons of data. I’m going to update the article with this information too.
#9
Taron, I am using a NodeMCU so it is the same controller as in your getting started example. Everything is setup as per your blog. Has the MQTT library or something changed since you wrote the blog, if so, can we use the same version as you used when writing your blog?
There is one thing different is that I am using a DHT11 not DHT22 - could that be the cause of the different packet size. I do not have a DHT22 to check against, on the serial monitor the data looks like:
“Humidity: 64.00 % Temperature: 25.00 *C 77.00 *F Heat index: 25.23 *C 77.41 *F
Reported!”
#10
The two sensors look the same ( in terms of configuration ). However, this is a problem with a library the firmware is using. So, it’s not a problem with the code you have, just the library.
Here is the problem: MQTT has a payload memory limit. You are sending humidity, tempC, tempF, heatIndexC, and heatIndexF. The default memory limit is not enough to support all of these values. The error is also not apparent, which makes it hard to track.
You can fix this in two ways:
  1. So, you can only send the data you need. You can edit the void report function to seen one or two values.
  2. Or you can increase the memory limit:
#11
@Taron_Foxworth In deed that resolved the issue. Thank you, but please put a note for this in your article https://www.losant.com/blog/getting-started-with-the-esp8266-and-dht22-sensor it took me so much time debugging, i am luck to find this article. I almost gave up on this great losant.com!
