It would be helpful to be able to directly mutate the current item in the Loop node and have those changes be persisted back to the loop source.
I’m trying to create an endpoint that returns an array of devices, and also includes the status state for each device in the response.
The use case is to loop over an array of device objects, retrieve state for each device within the loop, and add that state to the current device object for the loop. If I use the Gauge Query node and set the payload path to loopCurrentItem.value.status
, this mutation seems to get lost on the next iteration. (Seems like the loopCurrentItem
is just over-written on each iteration.) The documentation makes it sound like if you include a Next node in the loop, it will retain modifications to the payload, but that doesn’t seem to happen for the current loop item.
As a work-around I’m using a Function node within the Loop to place the status state back on the corresponding device object in the array:
const status = payload.loopCurrentItemStatus; // The result of the Gauge Query for the device's status
const index = payload.loopCurrentItem.index;
payload.devices[index].status = status;
I imagine that mutating the current item within a loop will be a common scenario. It would be great if the Loop node allowed for direct manipulation of the current item.
