[Solved] Can't connect to Losant with ESP32
I can’t connect to Lasant with ESP32
mqttClient.state -1.
Losant application log is “No logs yet Listening”
serial log is
Running Workshop 3 Firmware.
Connecting to MakeySQ
WiFi connected
IP address:
192.168.0.20
Connecting to Losant...-2
.-2
.-2
source code
 * Workshop example for periodically sending temperature data.
 * Visit https://www.losant.com/kit for full instructions.
 * https://www.losant.com
#include <WiFiClientSecure.h>
#include <Losant.h>
// WiFi credentials.
const char* WIFI_SSID = "";
const char* WIFI_PASS = "";
// Losant credentials.
const char* LOSANT_DEVICE_ID = "";
const char* LOSANT_ACCESS_KEY = "";
const char* LOSANT_ACCESS_SECRET = "";
const int BUTTON_PIN = 33;
const int LED_PIN = 27;
const int TEMP_PIN = 39;
bool ledState = false;
WiFiClientSecure wifiClient;
void toggle() {
  Serial.println("Toggling LED.");
  ledState = !ledState;
  digitalWrite(LED_PIN, ledState ? HIGH : LOW);
  if(strcmp(command->name, "toggle") == 0) {
    toggle();
void connect() {
  // Connect to Wifi.
  Serial.println();
  Serial.println();
  Serial.println(WIFI_SSID);
    delay(1000);
    Serial.print(".");
  Serial.println("");
  Serial.println();
  device.connect(wifiClient, LOSANT_ACCESS_KEY, LOSANT_ACCESS_SECRET);
  while(!device.connected()) {
    delay(500);
    Serial.println(device.mqttClient.state()); // HERE
    Serial.print(".");
  Serial.println("Connected!");
void setup() {
  Serial.begin(115200);
  // Giving it a little time because the serial monitor doesn't
  // immediately attach. Want the workshop that's running to
  // appear on each upload.
  delay(2000);
  Serial.println();
  Serial.println("Running Workshop 3 Firmware.");
  pinMode(BUTTON_PIN, INPUT);
  pinMode(LED_PIN, OUTPUT);
  connect();
void buttonPressed() {
  Serial.println("Button Pressed!");
  root["button"] = true;
  device.sendState(root);
void reportTemp(double degreesC, double degreesF) {
  root["tempC"] = degreesC;
  root["tempF"] = degreesF;
int buttonState = 0;
int timeSinceLastRead = 0;
int tempSum = 0;
int tempCount = 0;
void loop() {
  bool toReconnect = false;
    toReconnect = true;
  if(!device.connected()) {
    toReconnect = true;
  if(toReconnect) {
    connect();
  device.loop();
  int currentRead = digitalRead(BUTTON_PIN);
  if(currentRead != buttonState) {
    buttonState = currentRead;
    if(buttonState) {
      buttonPressed();
  tempSum += analogRead(TEMP_PIN);
  tempCount++;
  // Report every 15 seconds.
  if(timeSinceLastRead > 2000) {
    // Take the average reading over the last 15 seconds.
    double raw = (double)tempSum / (double)tempCount;
    // The tmp36 documentation requires the -0.5 offset, but during
    // testing while attached to the Feather, all tmp36 sensors
    // required a -0.52 offset for better accuracy.
    double degreesC = (((raw / 1023.0)) - 0.5) * 100.0;
    double degreesF = degreesC * 1.8 + 32;
    Serial.println();
     Serial.print("Raw: ");
    Serial.println(raw);
    Serial.print("Temperature C: ");
    Serial.println(degreesC);
    Serial.print("Temperature F: ");
    Serial.println(degreesF);
    Serial.println();
    reportTemp(degreesC, degreesF);
    tempSum = 0;
    tempCount = 0;
  delay(100);
  timeSinceLastRead += 100;
It looks like at the moment, the Arduino MQTT client is unable to connect over SSL - we are looking into why internally. In the meantime, you can connect over an insecure channel - you want to use WiFiClient instead of WiFiClientSecure and use device.connect instead of device.connectSecure.
I have changed code that use WiFiClient instead of WiFiClientSecure and use device.connect instead of device.connectSecure.
unfortunately, Errors continue to occur.
Serial log is below.
WiFi connected
IP address:
192.168.0.20
Connecting to Losant…-1
.-1
.-1
.-1
.-1
.-1
.-1
.-1
.-1
.-1
Are you able to connect to brokers other than Losant with the PubSub client directly? Are you perhaps behind a firewall that is preventing connections over ports 1883 (insecure MQTT) or 8883 (secure MQTT)?
I don’t know how to connect directly to brokers. Please, Can you give sample code?
I run code in below link using WIFI and SmartPhone tethering.
the result is same.
https://forums.losant.com/t/cant-connect-to-losant written by Brandon_Cannaday
and serial log is
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
ets Jun 8 2016 00:22:57
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:928
ho 0 tail 12 room 4
load:0x40078000,len:8488
ho 0 tail 12 room 4
load:0x40080400,len:5832
entry 0x40080698
…Connected to WiFi
Failed to connect.
-1
I have tested WIndow app. app name is MQTT.fx.
When using Window app, it is success.
Connection profile setting
MQTT Publish screeshot
MQTT subscribe screenshot
I don’t know why can’t connect to losant MQTT broker?
Please help me.
Hey Michael, i’m still unable to connect securely but am able to connect unsecure.
When will that be fixed? if it is fixed - what should i do?
Roy
We have both the ESP32 and MKR1000 connecting successfully both securely and insecurely now: MKR1000 hangs on trying to connect to Losant
I have the same problem, unable to connect securely but am able to connect unsecure. However, my device is the NodeMCU ESP-12E.
